James Sweet
I messed with this thing some more and am still stuck. Press the power
button and the green light comes on, HV comes up, about a second later the
relay clicks and the PSU shuts down. Power light remains on and the other
two LED's illuminate. Remote (which I think was working before) doesn't turn
the set on or off.
So far I've:
Replaced arcing flyback, that got the set up and running briefly but I
turned it off to reassemble and then it started this shutdown thing
Resoldered entire power board
Resoldered most of the sweep board
Resoldered yoke interconnect board
Checked all the diodes, transistors, and fusible resistors on both the power
board and sweep board
Measured voltages out of the power supply including HV, all appear within
spec for the ~1 sec it'll stay powered on
Grumbled, cursed at it and brooded
I'm wondering if I should just hope to find a known good chassis for it?
Someone told me it's a PTV300.
the set on or off.
So far I've:
