Philips 41JP20 shutdown
Discussion in 'Electronic Repair' started by James Sweet, Jun 17, 2004.
  1. James Sweet
    James Sweet Guest
    Ok I'm back again with this pesky thing. Finally got the replacement Diemen
    flyback, installed it, set came up but HV was about 8kv. Realized pins 1 and
    3 need to be swapped for it to be wired as in the schematic, do that and set
    comes up more or less normal. Now the bad news, I shut it off, unplugged it,
    and put in the rest of the screws holding the power board in, plug it in and
    turn it on, it fires up for a moment then shuts down. Monitored the HV,
    fired it up again, HV comes up normal for a moment before relay clicks and
    the set shuts down. I'm at my wit's end with this thing, what things can
    cause shutdown with this set and where do I start?
  2. techforce
    techforce Guest
    Could be bad solder on the power board that when screwed down cause bad
    connection. The Really old NAP's had bad solder Feed-thru's on the old
    Boards, and sometimes even on the AC Line Terminals, causing the Flyback to
    fail because it would be overheating. I would go through all the solder
    everywhere since its an older set.
    Diemen
    and
    set
    it,
    and
  3. James Sweet
    James Sweet Guest
    Already did that the first time I fixed it before the flyback failed, guess
    I can go through it again though.
  4. techforce
    techforce Guest
    The fact you said it changed when everything was buttoned up would tell me
    it has something to do with that action. Try Running it un-buttoned, and
    Flex / Vibrate the boards in question.
    Flyback
    | to
    guess
  5. James Sweet
    James Sweet Guest
    Yeah, though I also thought that perhaps the power cycle caused something to
    pop, I'll have to go through it again.
