Philips 41JP20 flyback number?
Discussion in 'Electronic Repair' started by James Sweet, Jun 6, 2004.
  1. James Sweet
    James Sweet Guest
    Still awaiting an answer on this one, the set is a Philips 41JP20, flyback
    is visibly arcing internally. Power board is 00APW010-D004, number has
    fallen off flyback transformer. This is the TV in my mom's livingroom so
    she's been bugging me every time I go over there.
  2. techforce
    techforce Guest
    Its a PTV330 chassis. Loc: T4 = 483514067162 / 362140-1,-2 / HR6493
  3. James Sweet
    James Sweet Guest
    Thanks!!
  4. John Del
    John Del Guest
    Subject: Re: Philips 41JP20 flyback number?
    Aren't the 362140 dash 1 and 2 different? I thought one used the pigtail lead,
    and the other used the barrel type because of different HV splitters, no? Or
    will the HR6493 sub both?
    John Del
    Wolcott, CT
    "I'm just trying to get into heaven, I'm not running for Jesus!"
    Homer Simpson
    (remove S for email reply)
  5. techforce
    techforce Guest
    HR says it will sub for both. It could well be what you cay about the
    connectors is true, but they usually leave a small degree of Fabrcation up
    to the servicer if something like that happens to exsist. They wont make 2
    Molds for a flyback with such a mild difference.
    | >From: "techforce"
    | >Date: 6/6/04 7:03 AM
    | >Message-id: <>
    lead,
    Or
    | John Del
    | Wolcott, CT
    | Homer Simpson
  6. John Del
    John Del Guest
    Hehe...I'm old enough to remember using Thordason and Triad subs for fllys
    years ago, and learned to carefully follow the little sheets that came with
    them, in order to wire for different apps.
    But the two NAPs are different to be sure. I once subbed one for the other,
    and it ran about 10 minutes with almost zero focus, before the front of the
    flyback (that covers the divider portion) blew out. I never tried the sub in
    reverse though.
    John Del
    Wolcott, CT
    Homer Simpson
