S
Sidney
Philips 4 head vcr model:VRT542AT02,year:Jan 1996,UL:4C43,FCC ID
code:ASIPAE027,CSA File:LR66446 which is a JVC chassis.When the AC
plug is plugged in the unit's tray cage loads down without a tape and
goes into full play mode but there the video heads don't spin nor does
the capstan motor nor is there any life to the VF display,no functions
work.
The unit has the basic 5v,12v,17v and -26v or so here and there but I
cannot isolate the problem,the SMPS power supply seems fine and no
open ic protectors or low ohms resistors,I cleaned the mode switch but
no luck,I need common repair tips and a schematic diagram.
So if anyone could look up repair tips at:
http://www.Euras.com
http://www.winstip.com
http://www.repairhelper.com
http://www.shophelper.com
http://www.circuitwork.com/techassist/cgi-bin/yabb/YaBB.cgi
http://www.network54.com/Forum/27725
http://www.nesda-ohio.com
http://www.anatekcorp.com
Or any wheres else,thanks in advance.
Sidney
Dartmouth,Nova Scotia
Canada
work.
Sidney
Canada
