Philips 32pfl3606h/58 ON/OFF
Discussion in 'Troubleshooting and Repair' started by Nbdy, Oct 19, 2019.
  1. Nbdy
    Nbdy
    4
    Oct 19, 2019
    Have a 32pfl3606h/58 from philips,which when I plug him in turns on,and then off (1-2 sec) ...
    The PSU board looks OK,no damaged caps,no damaged fuses ...
    Tryed to measure the 24V,12V,5V where I on 5V get 12V ...
    any advice
  2. Harald Kapp
    9,668
    2,019
    If that is truly the case and not due to a wrong measurement, the overvoltage on the 5 V line is likely to have burnt a few components in the meantime.
  3. Nbdy
    Nbdy
    4
    Oct 19, 2019
    All seem OK,the PSU is single ...
    Do I have to short somthing to get the PSU to work ???
  4. Nbdy
    Nbdy
    4
    Oct 19, 2019
    OK,after a remeasure there is 4.74V on 5V pin
    ENA - 50 mV
    DIM - 270 mV
    12V - 0V
    24V- 250 mV
    5V - 4.74V
    S/B - 0V
  5. 73's de Edd
    73's de Edd
    2,805
    1,176
    Aug 21, 2015
    Sir nobody . . . .
    Someone here !
    Pls confirm that I am using the correct schematic for that rare duck . . . .
    Wherein . . . . circuit wise . . . . .
    The units 24V and 12 V cold supplies are derived from an IC902 / NCP1271 that drives a Q901 FQPF3N80C
    The units +5V cold standby supply is derived from an IC901 / TNY274 that drives T902 transformer directly.
    The inverter power supply is being a separate circuit .
    If the above is correct, check and see if circuit associated C933/2200 [email protected] v or C934/47 ufd @50V havent gone "soft " on you. Expecting that 4.74 VDC SBY to rise on up.
    73's de Edd . . . . .
    The reason that cream costs so much more than milk . . . . is because its more involved and expensive to train the cows to sit on those dern small bottles.
  6. Nbdy
    Nbdy
    4
    Oct 19, 2019
Similar Threads
Loading...
