jkgoodall
I have 2 Philips 32FL2881/75R wide screen tv's with faults. ( FL2-
chassis ).
The first one's picture is about 2/3 the normal width and seems to hav
totally lost verticle sync but I think I can just make out a pictur
there. I only get sound for the first few seconds after I turn it on
The PIP picture is ok. On av/svhs it tells me there is no signal.
The second one.
It started out working fine but shutting the picture off after a fe
minutes when the weather was very hot and humid. The sound was fine. I
does not matter if you use the tuners or av/svhs inputs. Now It seems t
have lost both verticle and horozontal sync,the picture seems ok but fo
this. The sound is still ok.
Also as this is a 100hz model is there a mod I can do or module I ca
install to give it either SCART, component or VGA inputs ?
I am a electronics tech but in industrial electronics and have neve
worked on TV's before, so any help anyone can give me is very welcome
chassis ).
The second one.
