Philips 25GR6770/75R cycling off and on
Discussion in 'Electronic Repair' started by Larry, Jul 6, 2004.
  1. Larry
    Larry Guest
    Hello,
    Does anyone have any ideas on this? When I power on set, it gets to the
    point where the raster shows but then cycles down. This repeats until
    the set is powered down. Have checked for obvious bad components and
    bad solder joints but since the set powers off, it is not possible to
    take any measurements.
    Any help greatly appreciated.
    Larry
  2. This is usually attributed from failing components in the power supply
    and or scan circuits.
    In seeing how you presented the question, you would be best off to
    send the set out to a service center. It takes proper training,
    service tools, service information, and the proper setup to be able to
    service these sets.
    Jerry G.
  3. b
    b Guest
    If you can use a soldering iron, try replacing all the caps on the
    high volage line (typically rated 160v or more) and power supply.
    Don't forget to let the set stand for a few hours before staring, to
    discharge the caps fully.
    If that doesn't solve it, get the set to a shop for a proper estimate
    and visual inspection, the internet is not ideal to trouble shoot this
    type of thing.
    Ben
