Joerg
JosephKK said:Joerg [email protected] posted to
sci.electronics.design:
I still remember many EE exams where my brain went like this: I knowPaul said:Joerg wrote:
[snip]
Shouldn't be. Power folks also consider 360 degrees full circle.
Now when they introduced a 400 degree convention I bailed ;-)
Don't worry. That convention is now gon.
it's wrong but I've got to do it anyhow so that I pass. Like
impedance matching of a large transmitter final amp which, if it was
ever done, would result in flying glass and a 5-alarm blaze.
It should not have had that effect in a correctly designed unit.
Quite the opposite in fact.
Final amps of modern transmitters are low-Z (as seen after the matching
network). On really modern ones they are essentially fast switches. If
the fiaal amp had a transformed Z of 50ohm and the antenna had the same
you'd see a whole lot of dissipation. Modern transmitters can get pretty
close to 90%.
Impedance matching is usually only done in installations like a CATV
distribution because they have to assume that the far end is rarely
terminated with the proper 75ohms. Usually done via a series resistor.
Do that in a 100kW AM transmitter ... phsssst ... BANG.
