M
MooseFET
At what point is audio distortion perceptible by the general public?
0.1% THD? 1% THD?
I googled double blind distortion, but didn't get much quantitative
data.
I will assume that you've read all the other replies and not repeat
the good points there.
Perceptible can be hard to define. At small levels of distortion,
music sounds "different" but it is hard to put your finger on what is
different about it. It can sound like it is louder than you would
like it to be or perhaps like something weird has happened to the high
end of the frequency response. These things are very subjective and
vary a lot with the type of music etc.
At something like 5% many people will say "This is distorted". It
starts to become obvious that it is distortion that is what is
different.
Below 5% people can hear the difference if you switch back and forth
between distorted and undistorted. Depending on the details of the
type of distortion, most people can hear down below 0.1% distortion.
An output stage with cross over distortion and enclosed in a feedback
loop makes the sort of distortion that is most easy to hear. When a
low frequency signal causes the output to cross through the dead band
of the cross over distortion the output does something like this:
Ascii art:
This produces a large amount of some of the higher harmonics of the
low frequency.
