N
N_Cook
I've only used full size hot air gun and protective masking-off before. I
prefer the short sharp shock of full size rather than the "proper" pulse jet
type things, presumably for rework only really.
Couldn't resist one in a pound shop, unbelievably precisely small spot of
flame and also adjustable (upwards), amazing engineering, minimum about 1mm
diameter.
For SM salvaging rather than just removal, any other tips from actual users?
Seems necessary to hold the pcb vertical in a vice and hold the pencil
with flame upwards about 20 degrees of angle so butane liquid is not at the
outlet.
Mask off surrounding areas (including body of IC) with PTFE or woven glass
matt cut to fit the paricular situation.
Sub mm tungsten wire or something strong enough in those dimensions to
push under the IC or the pins , to loop around, and tug on while heating.
Freezer spray blast just prior to heating pins.
For DIP do one side of pins at a time, while tugging ?
Scalpel blade , perhaps bent, under pins ?
What sort of lighting is best ie to see the flame but also the work?
diameter.
outlet.
