How do you find the peak voltage output for each stage, when there is a voltage ramp input ramping from 0 volts to 5 volts
Since the input from the 1st stage is a voltage ramp input ramping from 0 volts to 5 volts, how do you get the peak voltage output for each stage , from stage to stage to stage?
It's really hard to get the peak voltage output for each stage because the input voltage is ramping or sweep from 0 to 5 volts
