PDIUSBD12 returns Buffer Overrun
Discussion in 'Electronic Design' started by Ganesh Okade, Oct 10, 2004.
  1. Ganesh Okade
    Ganesh Okade Guest
    Dear Experts,
    I am using PDIUSBD12 from Philips in my embedded device. I am able
    to successfully enumerate the device from a Windows driver. I am using
    end point 1 IN/OUT for my data communication.
    I have successfully been able to write data from the device to
    Windows. But this was only one bytes at a time i.e. I write one byte
    to the end point buffer and issue the Validate Buffer command (0xFA) -
    work fine. Now in order to improve the throughput, I started writing 2
    bytes at a time - works fine. But the moment I start writing 3 bytes
    in one shot, the communication stops and the Windows driver reports
    that the device responded with a BUFFER OVERRUN error (I get the
    following error code in the Windows driver - USBD status = C000000C
    (USBD_STATUS_BUFFER_OVERRUN). I understand that the buffer size in
    PDIUSBD12 is 16 bytes in size. Then why this buffer overrun?
    For your information I have a circular buffer into which the
    application software on my embedded device puts data. The the USB
    firmware pics data from this buffer and transmits it. Most of the data
    transmission happens from within the EP1 transmit ISR with the first
    byte being forcibly written by the application software to trigger a
    chain of interrupts causing the rest of the data bytes in the buffer
    to be transmitted.
    I want one more information - when a EP1 transmit ISR fires does
    it mean all the data bytes in its buffer have been transmitted or only
    one byte has been transmitted.
    Regards,
    Ganesh Okade
    Sunlux Technologies Ltd.
    www.sunlux-india.com
  2. Ganesh Okade
    Ganesh Okade Guest
    Dear Experts,
    I happened to resolve this problem and so thought I should post
    the solution. It was so happening that in the PDIUSBD12 firmware I was
    writing to the EP1 buffer 8 bytes at a time but on Windows side I was
    reading at the rate of 1 byte in one URB/request. This was causing the
    buffer overrun on the firmware.
    I also found that EP1 interrupt fires after ALL the bytes in its
    buffer are transmitted.
    Thanks.
    Ganesh Okade
