PCMCIA serial port card
Discussion in 'Electronic Repair' started by Sam Goldwasser, Sep 28, 2005.
  1. Anyone have an extra one of these laying around? I need to be able to
    control two RS232 devices from one laptop. It looks like they are $25-30
    on eBay once shipping is included.
    Thanks.
    --- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
    | Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
    ignored unless my full name is included in the subject line. Or, you can
    contact me via the Feedback Form in the FAQs.
  2. Ray
    Ray Guest
  3. $50+shipping, twice eBay prices.
  4. James Sweet
    James Sweet Guest
    It's one of those things that was never very popular because few people
    needed more than one serial port on a laptop and these days serial ports are
    pretty much dead for most people. You might be best off getting one from
    ebay, I've never even seen one up close and I've got a lot of random
    computer bits.
  5. Sorry, this is a dinosaur - but a useful dinosur though since it servces my
    needs in controlling lasers and data acquisition widgets.
    What about a parallel to serial port converter? :)
  6. Alex Bird
    Alex Bird Guest
    I'm assuming you already have one serial port - I've seen a project
    online where a guy converted an old unneeded pcmcia modem into a serial
    card for his sony vaio, which had no ports at all.
    Lots of old card modems lying around now I reckon... could be an
    interesting project!
    Alex
  7. When somebody suggested few had ever been interested in a PCMIA serial
    port, my reaction was that likely people did add things that bypassed
    the need for a serial port. Your suggestion reinforces that, since likely
    people would be more interested in adding a modem than just a serial port.
    On the other hand, it may be that the vintage is too late. Ten years ago,
    I took an ISA 2400Baud modem and yanked the UART, adding some line drivers
    and receivers so I had a 2400 Baud serial modem to use with my Mac.
    I would have duplicated the process with a faster modem later, but by
    then there was no standalone UART. It was part of some LSI IC, and there
    was no way of accessing the needed points.
    Michael
  8. Yes, one DB9 serial port and an internal modem that I think is COM2.
    I need COM3 or higher.
    A Sony VAIO would be another possibility - I have the port replicator but
    alas, that only provides a single serial port!
    But this KIWI dinosaur would be much more appropriate as it's so ancient
    as to have no other good use.
    That's a thought - I've got plenty old PCMCIA modems myself. But even if
    I only value my time at minimum wage, it's going to be more than for one
    from eBay! :)
  9. Ray
    Ray Guest
    A lot of pmcia serial card and especially usb to serial cards wont work for
    all applications.
    The Eigar serial port works like an original port, and drivers are available
    for Dos and Windows. I f you have a dinosaur application, you may need it
    to work in DOS.
    Ray
  10. At least one of the applications is genuinely Windows compatible. :)
    The other is a terminal emulator and while I'm currently using an ancient
    copy of Procomm Plus, and terminal emulator that has certain terminal types
    included in its database will be fine. But since COM1 can be the built in
    port, that really doesn't matter.
