Where can I get the spec on PCI-X pinout? Also does it have 5V power available? Thanks, Nigel.
PCI-X, has the same pinouts as PCI. You have the extra connector for the 64bit version, and it can run at a faster clock. Pinout: http://pinouts.ru/Slots/PCI_pinout.shtml If instead you mean PCI-Express, then: http://pinouts.ru/Slots/pci_express_pinout.shtml PCI-X, has 5v available (even on the 3.3v versions, there are a couple of 5v pins), but PCI-Express,only has 3.3v for the logic, and 12v for things needing higher voltages. Best Wishes
Thanks Roger, It was the -X I was after, I couldn't find any references to the availability of +5V on my searching. Best wishes, Nigel.
