S
smithodude
If a system contains a PCI-PCI bridge with an arbitrary PCI device
(call it Device X) on the furthest PCI bus (the bus most remote from
the Host Processor) how is the Configuration space of Device X
'discovered' by the OS on startup?
I understand that the IDSEL pin of Device X must be hard wired (via a
resistor) to a high order address line, but how does the PCI discovery
software actually find this configuration space if it doesn't know
which address IDSEL is wired to? Does the OS need to be informed of the
absolute address of the config space of remote devices?
I am running VxWorks on a DY4 board. My fellow software engineer has
written code (I can't remember which function calls he used) that lists
all the 'discovered' PCI devices. Device X is NOT amongst them.
Matt
Matt
