T
Tim Shoppa
Paul Burridge said:"Motorboating"? Is that some sort of ripple?
It's a form of ripple induced by the output stage load that causes
the whole circuit to oscillate. Imagine a
comparator that drives a medium-current load like a relay. The voltage
rises above the threshold (which comes form a voltage divider from the
power supply), the comparator turns the output on, and the load pulls
the power supply downa fraction of a volt. The threshold (because it
comes from a divider on the power supply) now drops, the comparator
turns off, and the cycle repeats. Frequency is often in the 10-50 Hz
range (hence the "motorboat").
It's not as big of a problem today with the widespread availability of
stiff voltage regulators being so cheap and the usual isolation of "power and
logic" supplies from "analog" supplies, but it happens, especially when
electrolytics dry out and no longer do their job. I stated
the problem in terms of droop on the power line but with non-zero
impedances on ground connections, "ground bounce" as a result of loads turning
on and off can induce a similar thing.
It can also happen with pure analog circuits but generally the
designers of these use topologies that are nearly insensitive to this
oscillation mode. Start cascading a couple of common-emitter amplifiers
though and you'll run into it.
Tim.
