P
Prasad
I'm using PCB mountable ECO-PAC diode modules from Powersem for a
rectification application where the current is about 180A rms. The
size of my circuit limits the PCB size to about 35mm x 60mm. The
length of each track is about 20-25mm. My PCB fabricator has
recommended to use tracks of 150 micron thickness. I have designed my
PCB such that most of the area is covered by the current track. Also,
i have used a PTH, double-sided PCB.
My doubt is:
(1) Will my PCB carry the required 180A current.
(2) If not, what changes can i make to my design (given the limited
space available) to pass the 180A through the tracks.
(3) Is there any thumb-rule or formula to calculate the track
thickness for the required current.
Any help will be appreciated.
- Prasad.
My doubt is:
- Prasad.
