N
N_Cook
Intermittant cutting out of an amp , something to do with the uPC1237HA
protection IC. Number of control inputs (o/p DC fault sense etc) that takes
o/p low of main speaker relay which clicks over. In fault mode this o/p goes
to 60V via the relay, all quite normal and in spec but for a small SIL IC
with 3.4V on the supply pin, a bit disconcerting. Incidently what does Vcc
mean wnen an IC is rated for 60 volt Vcc (from the NEC datasheet) but 3.4V
the recommended supply voltage
Next time coming across similar fault I will change the 100uF ,3 second
power-on-delay timer , temporarily, for 1 or 10uF as although the main fault
would operate immediately it would take 3 seconds to reset making tracing
infuriating as not immediate on/off.
Changed the IC and caps around the IC and just about to change Rs around it
although nothing has checked bad - still the problem persists. I decided to
change the 4.7uF electrolytic (power off muting one) for the second time
(most twizzle sensitive to inducing fault near this C) and this time the
solder pad came away with the molten solder.
Of course everything all nearby and elsewhere concerning soldering and pads
looked fine and tested for continuity fine.
Perfect ring of solder with a white pad (like overlay printing)
showing under the solder blob , with the cap wire still in place passing
through. Track , perfectly wide about 2mm, had failed in a neat circle
around the pad. Only ever touching contact between track and solder pad or
resonance vibration effect tearing in use ? bearing in min only a very small
electro. Only 2V or 0V on this cap and less than 20mA , so I assume
manufacturing fault. What led to the fault and what to visibly check for (if
possible) with other pads before returning amp to owner ?
