Sotiris Bos
- Oct 7, 2016
- 9
- Joined
- Oct 7, 2016
- Messages
- 9
This will be a lengthy post so I will cut straight to the chase. I own a Krups Dolce Gusto coffee maker (https://www.amazon.co.uk/Krups-Nescafe-Melody-Manual-Machine/dp/B00843M0QC) that used to be in our summer house which had a problematic main power cable and thus had serious problems with the electricity. The whole area has a general intermittent voltage problem. The electrician came to replace the damaged cable and cut the power multiple times. It is then when the coffee maker stopped working and wouldn't turn on. I am very inexperienced with electronics (my experience is soldering a molex adapter on some LEDs to install in my computer). I thought I could tackle this.
I took it apart and found a varistor (TVR 14471) with a broken outer sheeth and two traces on the pcb that used to connect to it that were black. I watched a couple of pcb repair videos and soldered two cables in place (must have been aluminum, they are silver in color), after having removed the varistor completely. I tried it and it worked fine. The cables were very thick and the pcb wouldn't fit into its plastic holder, so I removed them and replaced them with two very thin copper cables. THEN, I probably foolishly decided to solder the varistor back on, since I got 1.500 kOhms resistance on it with a multi meter. I soldered it on the way it used to sit (I think). I plugged the pcb correctly inside the coffee maker and then I plugged it in the outlet. That is the moment when the thing exploded and knocked out the power from the power main of the apartment (the box of the electrical company which is in the entrance of the building, not the electrical box in my flat). I removed the pcb and took some photos of it that I am going to post below. Is it salvageble? Did I destroy anything else? (like the thing that looks like a small resistor and is marked as D1) The fuses are inside the coffee maker and I didn't check them.
