PCB making in the UK?
Discussion in 'Electronic Basics' started by Texy, Feb 22, 2004.
  1. Texy
    Texy Guest
    Is there a source of a pcb making 'kit' in the UK?
    Or any recommended UK based sites giving info?
    Cheers,
    Texy
  2. Gareth
    Gareth Guest
    Maplin sell things like that:
    www.maplin.co.uk
    If the link below doesn't work go to the "Cables and Components" section
    then "PCB & Circuit Development" subsection
    http://www.maplin.co.uk/Search/Resu...evel=1&Menu=17&Name=PCB & Circuit Development
    There are companies that will make PCBs for you if you supply the data
    in a suitable electronic format, have a look at:
    http://www.pcbpool.com/ppuk/info.html
    Only 49 Euros for a double sided PCB with plated through holes. I have
    used this company and their PCBs are certainly a lot better than you can
    make with a Maplin kit.
  3. Ian Bell
    Ian Bell Guest
    Do you want home stuff for a few prototypes or production kit?
    For home stuff I think Maplin may have what you need.
    Ian
  4. Texy
    Texy Guest
    I have looked at maplins - there 'kit' was around 60 odd quid - a lot
    more than I wanted to pay. They do sell a 'students' version for £18
    however.
    That might get me off to a start.
    Is there a recommended website to show you how to do it?
    What has confused me is that there seems to be two approaches to it -
    one using UV lamps, and the other not (and therfore different
    chemicals to use).
    Texy
  5. Texy
    Texy Guest
    Ok - I also found www.megauk.com who sell loads of stuff at reasonable prices.
    Texy
    Now to look for a website to show me how to do it!
  6. Ian Bell
    Ian Bell Guest
    I don't think you will find anything much cheaper than that for home use.
    You could always use veroboard instead.
    AFAIK the etching chemicals are the same. theonly difference between
    prototype processes is that the UV exposure method needs to developed and
    fixed like a film before etching whereas if you use a Dalo pin staight on
    the bare copper you don't.
    This site www.megauk.com has details of the UV process.
    Ian
  7. Bob Masta
    Bob Masta Guest
    For instructions on how to make simple direct-drawn
    (Sharpie felt-tip marker) circuits etched with ferric
    chloride, including tips on adjusting etchant concentration
    and drilling, you might want to check out
    <www.daqarta.com/lptxh.htm>
    Hope this helps!
    Bob Masta
    dqatechATdaqartaDOTcom
    D A Q A R T A
    Data AcQuisition And Real-Time Analysis
    www.daqarta.com
  8. Gareth
    Gareth Guest
    One way to make PCBs would be to just draw the tracks on a copper clad
    board with an etch resistant pen then put the board in ferric chloride
    solution until the copper you don't want has gone. Then remove the PCB
    and clean it.
    If you use this method then you only need:
    etch resistant pen
    ferric chloride
    copper clad board
    plastic tray
    rubber gloves
    water
    very fine abrasive cleaner
    You can by the pen, ferric chloride crystals and cleaner from Maplin,
    probably for a lot less than 60 quid. I think that is what the student
    kit consists of.
    Instead of a pen you can use etch resistant transfers, I think this is
    what the expensive kit consists of.
    If you use a UV light box the etching process will be the same, but
    instead of drawing the tracks on with a pen or transfers you use a photo
    sensitive etch resist which is exposed to UV through a transparent
    plastic film on which there is a 1:1 print of your artwork. You also
    need to develop the etch resist so an extra chemical process is required.
    UV light boxes appear to be over 100 quid which is probably beyond your
    budget. I have heard of people using sunlight instead of a UV box but I
    have no idea how well that works.
    Gareth.
  9. Try this:
    http://www.electricstuff.co.uk/pcbs.html
    petrus
  10. Forth time I post this reply. Hope it comes through this time.
    Try this:
    petrus
  11. Texy
    Texy Guest
    Well it got through 3 times!
    Thanks petrus
    Texy
