PCB Log Periodic Antenna
Discussion in 'Electronic Design' started by Bob Morris, Oct 24, 2011.
  1. Bob Morris
    Bob Morris Guest
    I need a log periodic broadband antenna covering the 700MHz to 4 or
    6GHz range for ambient field measurements. They are several hundred
    dollars from test equipment suppliers. But, with due respect, there
    doesn't seem to be that much to them, in terms of construction.
    http://www.spectran.com/HyperLOG7000_en.shtml
    Has anyone by chance seen a low cost PCB version of these for sale? If
    not, is one feasible, say using an applet like the one below to design
    the segments?
    http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=16289
    Bob Morris
  2. Uwe Hercksen
    Uwe Hercksen Guest
    Hello,
    the normally used PCB material FR4 will be not suitable for frequencies
    of several GHz, you should use a special HF PCB material.
    Bye
  3. Guest
    The cost isn't in the production, rather the design and calibration. That has
    to be made up on a fairly small quantity sold, so...
  4. Malcolm Faed
    Malcolm Faed Guest
    Hi Bob,
    Try http://winradio.com/home/antennas.htm
    Regards,
    Mal.
    "Bob Morris" wrote in message
    the segments?
    Bob Morris
  5. Nico Coesel
    Nico Coesel Guest
    Even if the material is very thin?
