Pcb light detector
Discussion in 'LEDs and Optoelectronics' started by Chris13, Nov 18, 2014.
  1. Chris13
    Chris13
    26
    Sep 16, 2014
    Is there such a device as a PCB mounted (any type) device which allows current to flow when it detects light?
    What I would like to do is have an LED light up when a voltage is applied, this then shines on a sensor which allows current to flow. The sensor then stops flowing when the LED is off.
    What I have found so far is RS642-4424 but I'm not 100% sure this is the right device.
  2. Supercap2F
    Supercap2F
    550
    150
    Mar 22, 2014
    How about something like this? You can adjust the light level it triggers at too. I can't find anything on the "RS642-4424" can you give a link?
    Dan
    Arouse1973 and hevans1944 like this.
