danny davis
- May 9, 2012
- 306
- Joined
- May 9, 2012
- Messages
- 306
What are some holders for PCB?
The only one i have found is PanaVise 324 Electronic Work Center
http://www.amazon.com/PanaVise-324-...PNBU/ref=sr_1_9?ie=UTF8&qid=1336624661&sr=8-9
The Microscope at my job doesn't have any room to put a Panavise or clamp to hold the PCB board down so it doesn't move
Right now when I'm soldering under the microscope the PCB keeps moving up and down and side to side I can't get it to stay sit
What can I use please?
Another problem is that my soldering iron when pointing straight up is to long to be in between the working area of the microscopes working area
It's very hard to keep the soldering iron at an angle because the shaft of the soldering iron starts to melt the SMT packages of other components or you can't get your soldering tip on the right pad that you're soldering so you need to point the soldering iron straight up or at 2 o clock angle but you can't do that because the microscopes lens or you will hit the microscope area
Most soldering irons are about 8inchs in length
the bottom working area of the microscope to the Magnifier lens is 3 to 4 inches
My soldering iron keeps hitting the magnifier lens so i can't point the soldering iron at a higher angle to get at the pads
