D
Hi, this is my first full eletronics project so this truly is a
beginner question. I'm making a device that uses a PCB to power 6
loads that will equal a maximum of 100 watts. And I'm wondering,
assuming the loads can go either way, should I go with 12 or 24 volts
for my power source.
Based on the I=P/V equation, a 12 volt power supply would result in
about 8 Amps on the board, and a 24 volt power supply would result in
just over 4 Amps on the board. Which is best? Would it make sense to
use a 24 volt power supply instead of a 12 volt one? How do you
compare the dangers of higher amps vs higher volts and what would I do
to make a 100 watt device like this safe?
