Categories
Platforms
Content
I have used inkjet transparencies as a mask to expose a photosensitized boards and then etched the boards. Been doing that for 15+ years.
What is your question?
John
With inkjet, all you need to do is make the transparency. Be sure to mirror it, if needed. Place the ink side against the sensitized PCB board, use single-thickness glass and clips to hold it down, expose to light, develop, and etch.
The procedure has been written up dozens of times and presented on the internet. There are small variations, like exposure time, developer, and stripper, that depend on the brand of board you are using. Follow the manufacturer's directions.
If you want to use LaserJet, I wrote up the procedure I have been using here:http://www.electro-tech-online.com/blog-entries/improved-laserjet-transparencies-for-pcb.213/
Many laser printers probably do not need the additional darkening of the image.
John
A couple more questions.
If I mirror the image while printing then place it print side down on the board, will this have the effect of mirroring the image back?
How do you know how long to expose for, is it possible to overexpose?
They will be OK, but finding a ballast for them with the right connectors might be a problem and they are a bit small - it will only be possible to expose small PCBs evenly. You would also have to build a box with a glass exposure surface and lid, so you don't look at the UV light. It might be better to look at
LED UV Exposure unit
or search for 'UV exposure unit' on fleabay. They have the box, convenient access and a timer built in.
Be aware that looking directly at UV light WILL damage your eyes (ARC eyes).
