PCB Etch Film Reusable Stencil?
Discussion in 'Beginner Electronics' started by Okidokee, Oct 3, 2004.
  1. Okidokee
    Okidokee Guest
    Does any one know where I can get a film I used one time that is like the
    ones screen printers use, is coated blue and once exposed can be used as a
    stencil for etching over and over again a good many times?
    After being exposed it is put in a developer and developed for about 30
    seconds. The great thing about this stuff is that it can be used as a
    stencil repeatedly instead of having to spray on sensitizer to expose a new
    board each time. You
    can just keep using the stencil.
  2. Z80
    Z80 Guest
    I think you are referring to PnP transfers (press and peel). They are available from Rapid Electronics UK - 5 sheets 8.5" x 11" for £13.40 - Tel. 01206 751166.
    May also be available from others but Rapid have a good selection of PCB equipment.
