I think you'll find it's 5.08mm between connectors, and the board is probably 1.6mm thick
That spacing is very common among larger or higher voltage connectors. It is 1/5 of an inch spacing, or double the 1/10 inch (2.54mm) spacing that is common in electronics.
I can't see enough detail to make an exact ID.
