PCB building
Discussion in 'PCB Layout, Design and Manufacture' started by HellasTechn, Apr 24, 2015.
  1. Sadlercomfort
    Sadlercomfort Ash
    424
    53
    Feb 9, 2013
    Looks good Constantine! :) Very neat
  2. chopnhack
    chopnhack
    1,571
    349
    Apr 28, 2014
    Agreed, that board looks perfect, good job - just need to tin it now ;-)
  3. HellasTechn
    HellasTechn
    1,406
    195
    Apr 14, 2013
    I am waiting for the tinning material to arrive :) . More pictures will follow.
    The scratches you see on the copper surface are because i use fine sandpaper to help apply tin or soldermask layer.
    Sadlercomfort likes this.
  4. chopnhack
    chopnhack
    1,571
    349
    Apr 28, 2014
    Don't use sandpaper - I have found that it scores too deeply - try steel wool instead - much better surface. Deep scores produced with sandpaper alter etching in my opinion.
    davenn likes this.
  5. HellasTechn
    HellasTechn
    1,406
    195
    Apr 14, 2013
    I know.
    The one i use is not simple sandpaper. It is special for use with metal and i work it with soap water. I dont know how you call it in english.
    I will try steel wool next time, Thanks.
  6. chopnhack
    chopnhack
    1,571
    349
    Apr 28, 2014
    Its wet sandpaper, typically black in color and has very fine grit - 400 to 1000 grit is common and is used often for rubbing down finishes in woodworking as well as in auto body work. I still don't use it for pcb's because we exert uneven pressure when sanding by hand and cut through too deeply in spots. Even when using a sanding block, I have found the edges end up getting knocked down first while the center needs more work. Steel wool for me only.
    HellasTechn likes this.
  7. HellasTechn
    HellasTechn
    1,406
    195
    Apr 14, 2013
    Yes that's the one.
    I will try it on my next board :)
    chopnhack likes this.
  8. HellasTechn
    HellasTechn
    1,406
    195
    Apr 14, 2013
    Here is the board finished !
  9. Sadlercomfort
    Sadlercomfort Ash
    424
    53
    Feb 9, 2013
    Wow that boards amazing mate.. love the component layer
  10. Sadlercomfort
    Sadlercomfort Ash
    424
    53
    Feb 9, 2013
    The other two pictures have only just popped up. Looks amazing =) the tinned copper looks really professional
  11. HellasTechn
    HellasTechn
    1,406
    195
    Apr 14, 2013
    Well i wouldn't say professional... but it is O.K.
    This board will last long trust me. We will probably not be around to see it failing, if you know what i mean ;)
  12. Sadlercomfort
    Sadlercomfort Ash
    424
    53
    Feb 9, 2013
    Can't complain with that ;) you should give yourself credit, it's easy to criticise your own work. It's hand made but it doesn't get much better than that.
  13. HellasTechn
    HellasTechn
    1,406
    195
    Apr 14, 2013
    Well, like i said, it is OK for hand made. It can not be compared with a machine made though.
    It's just that for small projects like the ones we do, a better PCB would be an overkill.
  14. HellasTechn
    HellasTechn
    1,406
    195
    Apr 14, 2013
    One more Board.
    chopnhack and Sadlercomfort like this.
  15. Sadlercomfort
    Sadlercomfort Ash
    424
    53
    Feb 9, 2013
    Very nice! =)
  16. chopnhack
    chopnhack
    1,571
    349
    Apr 28, 2014
    Came out great Constantine! Was it your design also? What is it for?
  17. HellasTechn
    HellasTechn
    1,406
    195
    Apr 14, 2013
    This is my latest board. I tined it by hand with a flat tip soldering iron and 60/40 solder wire. :)
