pc project - connecting all grounds to usb?
Discussion in 'General Electronics Discussion' started by welly_59, Sep 9, 2013.
  1. welly_59
    welly_59
    Sep 9, 2013
    i'm converting an xbox 360 wireless gaming headset to be compatible with my pc.
    I have found the pinouts on the av connector so its just a case of wiring them up correctly.
    I will be working with the following:
    Audio Left
    Audio Right
    5v power
    I will be using a modified usb cable to provide 5v power to the project.
    Now heres my question. All of them require ground, usually i would ground the power through the usb cable and then ground the audio cables through the ground of a 3.5mm jack. The pcb i am modifying has all grounds linked together, is it ok for this to be connected to USB ground?
    So my usb ground would have the power, audio left and audio right attached to it?
  2. welly_59
    welly_59
    Sep 9, 2013
    well its working, sort of. i'm getting a loud hum from the unit and music plays in only one ear. im going to try powering it from a usb wall plug instead of the usb socket on the pc, we'll see if that fixes anything
  3. CDRIVE
    4,960
    648
    May 8, 2012
    Hi and welcome to EP. Please post your schematic.
    Chris
