PC power supply
Discussion in 'Electronic Repair' started by onyxx, Sep 16, 2005.
  1. onyxx
    onyxx Guest
    Hello all, I am working açon a 250W SMPS from a PC. The primary part
    of the circuit work fine ( or so it seems) but the out put from the
    secondary is pulsating. I caonnect a small device i made out of 2 small
    light bulbs (one 5V the other 12V,I use this to quickly check for right
    voltage output)and i find is pulsating, like on off on off. Can anyone
    tell me why can this be? I tought of capacitors but they all seem fine.
    I dont have any equipment to check caps, I used a DMM. Any ideas?
    Gary.
  2. How much of a load are you lamps? You may need a couple amps on at least
    the +5 VDC line for stability.
    --- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
    Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
    +Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
    | Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
    Note: These links are hopefully temporary until we can sort out the excessive
    traffic on Repairfaq.org.
    ignored unless my full name is included in the subject line. Or, you can
    contact me via the Feedback Form in the FAQs.
  3. Does it do this when connected to the motherboard? It actually sounds
    like something is unhappy on the primary side...
    Tom
  4. Elec_Tech
    Elec_Tech Guest
    Is the supply current limiting? It sounds like its trying to start up,
    and then shutting itself down.
    If it is, then yes, it does sound like a control side issue. Closely
    inspect the pcb and components, using a jewelers eyeglass (95% of
    faults can be found, by careful inspection. To check that a transistor
    hasnt died, by desoldering one of its legs and measuring it. Also
    check for dry joints.
    Good luck.
