PC power supply
Discussion in 'Power Electronics' started by Udith Shan, Aug 16, 2011.
  1. Udith Shan
    Udith Shan
    Aug 16, 2011
    Any body know how to switch on a p4 power supply without connecting it to a mother board?:confused:
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    Google "PC PSU Pinout", or just ground the green wire.
  3. jackorocko
    jackorocko
    1,284
    Apr 4, 2010
    only about 50 youtube videos on this, jumper the green and black wires.
  4. davelectronic
    davelectronic
    1,087
    12
    Dec 13, 2010
    pc supply
    Go with the green and ground, black wire any molex black or the 24 pin sockets black.
    If it fails to start use a 10 ohm 10 watt resistor or a 10 or 20 watt lamp on the 5 volts rail red +black, there may be sense wires pink is common as is orange, but these are normally spliced together in the plugs, so should fire up ok, if its running and not blown that is. Dave. :)
