PC Power Supplies
redsierra
Jun 17, 2011
6
Jun 17, 2011
6
Can someone explain the difference and usefulness of -5 and +5 also -12 and +12volts in computer power supplies. What exactly is meant with minus or plus signs? Is there really a need for them to be inserted before the figure?
Thanks for your help, much appreciated.
davenn
14,260
14,260
Thats showing the voltage polarity relative to the 0V rail
so + or - 5V or 12V depending on the age of the PSU there may also be a 3.3V rail in there too.
cheers
davelectronic
Dec 13, 2010
1,087
Dec 13, 2010
1,087
The prefix just denotes that particular rail voltage, and the pin out for the ATX 20 / 24 pin molex connector for the supplys voltages for the mother board and other peripherals, the negative currents tend to be low in comparison with the + 3.3 + 5 and + 12 volt rails, there are other rails for other uses as well.
A picture diagram can be found on the web of all AT and ATX outputs.
Dave. :)
Resqueline
Jul 31, 2009
2,848
Jul 31, 2009
2,848
The power supply polarity is of vital importance to electronics, or else there be smoke. Compare it to the rotational direction of a lathe if you want.
The negative 5 & 12V supplies are very weak and are only remnants from a long past time when some obscure memory chips required dual power supply polarites.
Also the -12V is supposed to be used for the serial (RS-232) communication ports (no longer present in new computers).
The "distance" between +5V and -5V is 10V, and 24V between the +12V and the -12V.
daddles
Jun 10, 2011
443
Jun 10, 2011
443
The signs are very important; they tell you which way an electron will move in a wire subjected to that voltage. As mentioned, ignoring such vital information can result in smoke, damage, or an inoperable circuit.
redsierra
Jun 17, 2011
6
Jun 17, 2011
6
Re-pc power supplies
Thanks a lot for a quick response to my query regarding negative and positive voltages on psu. Your replies made it that much clear to a newbie. Tks once again
