F
fourrings
The combination of passion towards DIY and inability to find a
comparable quality solution, leads me to this question. I want to add
additional component inputs to my front projector. Active switches
introduce noise and are unable to handle the bandwidth. Off-the-shelf
passive ones lack quality. The slightest artifacts are quite apparent
on a 124" screen.
My solution is to take a three-pole rotary switch. Tie RGB ground
together at one point and use the switch to switch the signal leads
individually. The passive composite switch I have seems to have some
grounding through resistors. I'm aiming to achieve the same result as
if physically swapping cables. I also plan to incorporate an analog
audio switch in the same enclosure. My concerns are:
1. Is tying grounds together acceptable?
2. Does the switch need to be break-before-make?
3. Do I need to introduce any resistors, etc?
4. Does 1-3 apply to audio switching as well?
5. Thoughts on result?
Any input would be greatly appreciated!
on a 124" screen.
