Parts for a Toshiba M-782 VCR.
Discussion in 'Electronic Repair' started by Peter Easthope, Mar 13, 2013.
  1. Is any vendor still selling parts for a Toshiba M-782 VCR? I have one in which the cam gear or lever gear which lifts the right side of the cassette is broken.
    Thanks, ... Peter E.
  2. Tim Schwartz
    Tim Schwartz Guest
    I've used Andrew Electronics, an authorized Toshiba distributor. (or at
    least they used to be.) 1-800-289-0300 in the USA. Part likely to cost
    more than the machine is worth though.
    www.andrewselectronics.com/
    Regards,
    Tim Schwartz
    Bristol Electronics
  3. OK, thanks.
    Then there is the question of identifying the part. I can take a photo of it and describe it but don't know the part number. http://www.orderpartstoday.com/model/TBAM782/_/_/Toshiba/M782/ lists "70051147 GEAR, CAM [B440]" and "70051150 GEAR, LEVER DRIVE [K550]" either of which could be the part. When these machines were in vogue, Toshiba must have had part identification drawings. Do any such drawings remain available?
    Yes, an intact used machine might be cheaper. Thanks for the tips.
    Regards, ... Peter E.
