Part Info Needed, Toshiba CRT TV
Discussion in 'Electronic Repair' started by [email protected], Sep 6, 2006.
  1. Guest
    Model CX28510, Chassis: TAC9005. Resistor in p.supp. open, no way to
    tell value, please help identify R873, (1/2 watt flameproof).
    Thank-you!
    Cheers, Steve
  2. Don't say no way...my dad (an old oil field welder) always said "there ain't
    no such word as can't in the oil field."
    There are several ways in addition to #4 that you are trying here.
    1. Get the service manual and check the value. There are lots of resources
    online to do this.
    2. Contact a supplier for Toshiba parts like Andrews or Tritronics and ask
    their research dept or check their online search engine.
    3. Measure the two halves of the burned resistor and estimate the value.
    4. Get lucky and someone will have the manual handy to look it up for you.
    Sorry, I don't have this one.
    Leonard
  3. Guest
    Thanks Leonard, but I'm hoping someone has a 'board boneyard' that, at
    a glance, might have a board similar to this one. The resistor is near
    the switching xfmr. Thank you once again, will wait for another try at
    this. Just want to expedite the set is all!
    Cheers, Steve
  4. Guest
    These resistors used as fuses are generally easy to calculate. You know
    what i is flowing, pick your R to keep Pdiss just under the rated P.
    I assume youve fixed the real fault first.
    NT
  5. David Naylor
    David Naylor Guest
    Change out the Caps near the rgulator first and then get a 910 ohm
    flameproof 1/2 watt resitor and you should be goof to go
