Part identification help.
Discussion in 'Electronic Components' started by [email protected], Jul 5, 2003.
  1. Guest
    I am looking for what looks like a ceramic, wirewound resistor that
    came off the controller board in my threadmill. The item measures
    1.375" x .375" x .375" with 2 blade type connectors on the bottom. It
    has a symbol which looks like a diamond inside a square followed by
    the #s 7W 2K7J. I'm assuming it is a 7watt, 2K ohm. Where can I get
    such a part?
    Is this part supposed to run too hot to touch? The QC sticker attached
    to it turnrd brown from the heat.
  2. Hi Falcon,
    Sounds more like 2,7k 7W.
    Try local electronic shops.
  3. Guest
    I've been looking everywhere online and local Rat Shack. Can you
    suggest any sources? Thanks again.
    BTW, I put the multimeter on the resistor and it shows no reading.
  4. Hi Falcon,
    Well, I don't know where you live....try RS Components / Farnell,
    maybe the "famous" Radio Shack etc.
    HTH
    Wolfgang
  5. Also, you should try a higher power dissipation if the one you have
    failed due to overheating. Say, ten watts, maybe.
    @@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@,@@[email protected]@[email protected],@@[email protected]@[email protected]@[email protected]@
    ###Got a Question about ELECTRONICS? Check HERE First:###
    http://users.pandora.be/educypedia/electronics/databank.htm
    My email address is whitelisted. *All* email sent to it
    goes directly to the trash unless you add NOSPAM in the
    Subject: line with other stuff. alondra101 <at> hotmail.com
    Don't be ripped off by the big book dealers. Go to the URL
    that will give you a choice and save you money(up to half).
    http://www.everybookstore.com You'll be glad you did!
    Just when you thought you had all this figured out, the gov't
    changed it: http://physics.nist.gov/cuu/Units/binary.html
    @@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@@
  6. Guest
    Assuming it is a 2.7K 7 watt resistor, you can get
    it from Mouser Electronics.
    Order part number 280-CR10-2.7K
    That's 10 watts, 2.7K. It'll cost you more for the shipping
    than the part. If you have the space, a better approach
    is to order two resistors, and put them in series:
    280-CR10-1.2K and 280-CR10-1.5K - that'll give you 20
    watts.
  7. Guest
    On Mon, 07 Jul 2003 04:35:29 GMT, wrote:
    Thanks.
