I was working on a Jeep the other day that would not turn over when the
ignition switch was turned. It turned out to be the park/neutral switch. The
first thing I noticed was that the grease inside the switch was quite tacky
or sticky. So much so that two spring loaded contacts were sticking and
wouldn't move back after being pushed in slightly. The switch has six screws
holding it together and costs around $210 to replace. The contacts have been
cleaned and I'm trying to find a suitable lubricant to replace the lubricant
that was in it.
I've noticed that white lithium grease will turn tacky or sticky, but don't
know why. I've talked to a couple of different mechanics and they recommend
an anti-seize/lubricant compound, although when asked, they couldn't tell me
if the anti-seize compound is suitable for electrical type contacts inside
the switch.
Is there a grease that is stable and suitable for lubricating moving parts
in a switch?
Any information on this would be greatly appreciated.
Ken
that was in it.
the switch.
in a switch?
Ken
