Parametric sweep of model implementation
Discussion in 'CAD' started by Klaus Kragelund, Apr 28, 2005.
  1. Hi
    I´m using PSpice Capture 10.3
    One of my simulations on a SMPS I´m using a BJT as a switch transistor
    I would like to do a parametric sweep on the circuit with two
    different BJTs models (lets say the transistors are BC547 and 2N2222)
    to determine the optimum choice of transistor
    My method sofar is to use two global values in the parametric sweep (1
    and 2). Then in the position of the BJT there is a subcircuit with the
    two BJTs with both transistors in parallel with resistors on all
    connections
    The value of the resistors is determined by an IF command, that when
    the parametric value is 1 one set of resistors is 1mOhm and the other
    set 1Meg and vice versa.
    But this is a cumbersome method. The optimal would be that Pspice
    would allow the implementation name to change according to the needed
    model but that feature is not available
    So the question, do any of you guys have a better method for this
    problem?
    Klaus
  2. Jim Thompson
    Jim Thompson Guest
    Klaus,
    There is no provision for a library change in PSpice. HSpice does it
    with their .ALTER command.
    HSpice actually reruns the simulation with changes as stated in the
    ..ALTER.
    I've done it by concatenating .CIR files using an ordinary text
    editor. I've been known to concatenate as many as 32 different
    library corners into one simulation.
    Maybe I can convince the oldest son, the programmer, to write me
    another utility :)
    You can also do it now with v10.3 by using the Save As command in
    Probe. Save a version, rerun with changes, then append the saved
    data.
    ...Jim Thompson
  3. This is interesting. I would have though PSpice would implement
    something similar to what is in In TISpice, it uses rerun cards
    ..Reruns
    statments
    ..Rend
    You just make a file with as many reruns as you like, with each rerun
    specifying various parameters and libraries. SS does this for
    parameters, but not lib, so to change a model in this way, one would
    have to set each parameter of the model in a rerun. SS can generate this
    automatically.
    Oh dear..SuperSpice does this all within the GUI...
    http://www.anasoft.co.uk/WCSETUP.GIF
    All plots of all runs are all automatic.
    Or have a look at another simuater:)
    Kevin Aylward
