paralleling NIMH batteries
M
Martin Riddle
I have an idea that requires a large capacity rechargable battery and NiMH
seems to fit the bill. I need to charge them quick.
The problem is I'll need 2 or 3 strings of SC or D size cells. From what I
can gather connecting to the load is straight forward, but charging will
require contrl circuits for each string and relays to connect them.
Any other gotchas with this?
Cheers
M
martin griffith
Cheers
not always
http://www.linear.com/pc/viewCategory.jsp?navId=H0,C1,C1003,C1037,C1078
this looks good
http://www.gpbatteries.com/pdf/GP1300FH_DS.pdf
martin
M
MassiveProng
Cheers
Unless you have watchdog circuits and charge individually, you will
end up with a "memory effect". Of course, it is easily solved by Ind.
charging again.
W
Winfield
and NiMH seems to fit the bill. I need to charge them quick.
I've come to the conclusion that Li-ion is the way to go.
A
Anthony Fremont
charging again.
He said NiMH, not NiCd. NiMH batteries are _almost_ never affected by
"memory effect". You don't have to go thru that much trouble. People that
fly expensive RC models may have different opinions on that. ;-)
M
martin griffith
have you seen the seiko stuff?
such as ftp://ftp.sii.co.jp/pub/ic/speed_dt/dt_sht_e/power/S8242_E.pdf
martin
W
Winfield
such asftp://ftp.sii.co.jp/pub/ic/speed_dt/dt_sht_e/power/S8242_E.pdf
Hmm, an 800-cell PowerPack for my Prius would require 400 ICs?
