parallel port
Discussion in 'Beginner Electronics' started by Justice, Jul 11, 2005.
  1. Justice
    Justice Guest
    I want to learn how to control some small circuits through my parallel
    port but I do not want to damage my port. What can I use to make sure
    that I don't draw too much power or any other problems that may occur.
    I thank you.
  2. Landon
    Landon Guest
    Opto-isolators would be a good option.
  3. Justice
    Justice Guest
    Thank you but I'm new to electronics, ok fairly new I tinkered when I
    was a kid but forgot most of this stuff. Anyway What is a Opto-isolator?
    And how do i use one?
    A link ore simple diagram explaining this would be appreciated, a goggle
    search made my mind explode all I could get looked like engineering
    textbooks.
    Again I thank you
  4. JeffM
    JeffM Guest
  5. Landon
    Landon Guest
    This might be a good place to look:
    http://www.epanorama.net/circuits/parallel_output.html
  6. Rene
    Rene Guest
    Not cheap but good: Check out www.velleman.be (they can deliver all over the
    world I believe, I think ther're in the US as well) and search for K8000.
    Greetings and good luck with Your project!
    Rene
