P
Peter
I have read dozens of postings here and also all the FAQ's at Steve
Walz's site including zha96lpt.faq but can't find a straight answer on
this.
1. To input data via S4-S7 can I just wire up a 5v/0v input directly
to the pins with no resistor in between? I have actually done it and
it works fine but I was concerned about overloading the port -
particularly when I found that the pins on the parallel port are 3.6v
when "1" rather than 5v. (well within the 2.4v-5v TTL high range I
realise).
2. Most circuts I see apply 5v to the Status pins in the steady state
via a pull-up resistor then pull it low with a switch to input data.
Why is that preferable to holding them low in the steady state and
applying 5v to the pins to input data? Is it simply the possible extra
circuitry required with the latter?
this.
realise).
