Parallel port driver for PC
Discussion in 'Electronic Design' started by ted, Oct 14, 2003.
  1. ted
    ted Guest
    Can somebody suggest a low level parallel port driver for the PC
    (windows 2000)?
    This is to interface some digital controllers using TTL logic. The
    ..sys driver should preferable be free, easy to use, and allow very
    fast access to the I/O ports. High level software would be written in
    C
    I have been searching the net, but there seem to be too many offerings
    and not sure how good they are..:)-(
    I thought this newsgroup would be a good place to ask as there should
    be somebody here that's gone through this process before!!
    Thanks in advance
    Ted
  2. The one practically everyone uses is actually an example from "Writing
    Device Drivers" book and is distributed for free by
    http://www.driverlinx.com/DownLoad/dnload.htm with source as well as
    compiled version. There's example code in C and VB. Since the driver merely
    sets the permission for the user space to issue the io instructions, it's
    about as fast as possible.
    The driver shows up as "DriverLINX Port I/O Driver" under windows device
    manager.
  3. Norm Dresner
    Norm Dresner Guest
    Start at
    http://www.lvr.com/parport.htm
    and follow the links
    Norm
  4. Si Ballenger
    Si Ballenger Guest
    I use a free progrm called userport (search google for
    userport.zip) to get userlevel access to my parallel port pins.
    I've got a page below that shows how to use the parallel port to
    control a simple webcam switcher just using batch files.
    http://www.geocities.com/zoomkat/ppswitcher.htm
  5. Alan
    Alan Guest
    http://www.beyondlogic.org/porttalk/porttalk.htm
    Excellent program, with allowio.exe that's included with it you can
    open any port to any program. Works great to make older LPT port
    programs run with Win2000/xp.
    Also look at the menus at the blue bar in the page, there is a lot
    of good info here.
    Alan
