parallel led array
Discussion in 'LEDs and Optoelectronics' started by lightman, Nov 6, 2015.
  1. lightman
    lightman
    57
    Nov 6, 2015
    hi fellas this is my first post i am wishing to build an IR Illuminator for ghost hunting i want to make it from 3 5w high power ir led and wire it in a parallel led array so each led gets same power i worked out if i run them of a 3.7 volt battery i would need to add a 2.7 ohm resistor to each led so not to over power the led thing is i am only getting around one and half hours continuous use so what would i need to do to run same set up of two 3.7 battery's any help please fellas ?
  2. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Sounds like you know what you are doing... you scared me when you said parallel LEDs, but you are actually using a resistor on each one. Thanks! That gets missed by a LOT of people.
    As far as running with two batteries, simply connect the two batteries in parallel and your light should last twice as long!
    *Special Note : When you connect two unbalanced batteries in Parallel, you run the risk of causing current to flow between batteries. Never connect a fully charged battery in parallel with a used battery!
    The battery with the higher voltage will actually cause current to flow backwards through the battery with a lower voltage. So either connect them when they are both freshly charged, or when they are dead. You can always use a multi-meter to confirm the voltage is the same prior to connecting them.
  3. lightman
    lightman
    57
    Nov 6, 2015
    hi thank you for your help the new battery holder olds two battery's not sure I understand wire the two battery's in parallel do you have a pic sorry for being so dum
  4. lightman
    lightman
    57
    Nov 6, 2015
    its ok I see what you mean two single battery holders + soldered + - soldered to - with just a single wire from both battery's + and - is that right ?
    Gryd3 likes this.
  5. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    A solution for that problem is using Schottky diodes like this:
    The diode will drop about 0.3V(typ.),should be fine with a 3.7V bat. and IR led.
    Gryd3 likes this.
  6. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    GHOST HUNTING ???
    Do post a pic if you catch one...:eek:
    Anyways,
    as per my post above a good choice would be this diode:
    PMEG3050EP
    If you have the Battery and LEDs datasheets post them here.
  7. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Absolutely, but dorke posted a safer solution that wont require you having to balance your batteries before hand
  8. lightman
    lightman
    57
    Nov 6, 2015
    hi led data
    Emitted Color : Infrared IR 850nm 5w
    Viewing Angle: 135 degrees
    DC Forward Voltage (VF): 1.4V
    DC Forward Current (IF): 1400mA
    Maximum Pulse Voltage: 1.7V
    Maximum Pulse Current: 2000mA
    battery data GTL 18650 3.7v Li-ion Rechargeable Battery 5300mAh
  9. lightman
    lightman
    57
    Nov 6, 2015
    would I need a diode on each + wire and what size would I need to get thank you so much for your time and help
  10. lightman
    lightman
    57
    Nov 6, 2015
    it will not let me open your diode link can you get them on ebay many thanks
  11. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    yes, you need 2 diodes on each + wire, as shown in the #5
    the diode is PMEG3050EP here is it's data sheet:
    http://www.nxp.com/documents/data_sheet/PMEG3050EP.pdf
    So,
    you are running your LEDs at about 0.85A each for a total of about 2.5A.
    Your battery isn't very promising...
    see here(test of a GTL 2600mAh):
    http://www.candlepowerforums.com/vb/showthread.php?255943-GTL-18650-Battery-Test-Updated
    And,please watch the following video!
    https://www.youtube.com/watch?v=mbaSAyqhzxc
  12. dorke
    dorke
    2,342
    665
    Jun 20, 2015
  13. lightman
    lightman
    57
    Nov 6, 2015
    seems that make of battery are not very good were can I buy the diode I need please many thanks for your time and help
  14. lightman
    lightman
    57
    Nov 6, 2015
    your a star I will get two to try thank you so much for your help
  15. Colin Mitchell
    Colin Mitchell
    1,417
    313
    Aug 31, 2014
    Basically you cannot drive high power LEDs from a 3.7v battery and include a diode and current-limiting resistor.
    You do not have enough head-room - any ghost buster will tell you that.
  16. lightman
    lightman
    57
    Nov 6, 2015
    that's cool Colin I will forget the diode :)
  17. lightman
    lightman
    57
    Nov 6, 2015
  18. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Colin,
    Where does your bullshit come from...? :mad:
    Please,check yourself before you post,
  19. lightman
    lightman
    57
    Nov 6, 2015
    so was colin wrong dorky?
