Jamie Morken
I was thinking about how to minimize switching losses and also on state
resistance, as well as having reduced gate driver requirements, and
was thinking this would be a good idea:
use 1 fet with very fast rise/fall times as well as low gate charge
(but high on-state resistance)
then the rest of the parallel fets rise/fall times as well as gate
drive requirements are almost irrelevant. As long as they switch
within say 100ns they will relieve the single fet which hopefully
fully switched within 10ns, and then had normal Rds(on) losses
for 90ns. Then for 100kHz switching, the other lower Rds(on) fets
would take all the load for 10us, while the other "pulse" fet has
a chance to cool down until the next 100ns switch point.
So the benefits are reduced gate drive current requirements,
and not having to find fets that have BOTH low Rds(on) as well
as low gate charge and fast rise/fall times.
Another idea I was thinking, to use a zero ohm resistor on the
single fast fet, as the gate ringing may not matter on that
fet as long as it is able to stay turned on for at least 100ns
before the ringing turns it off.
Would these ideas be practical?
cheers,
Jamie
cheers,
Jamie
