Parallel Bridge Rectifiers. .
Discussion in 'General Electronics Discussion' started by cjdelphi, Dec 11, 2016.
  1. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    My bridge rectifier died, but i have several 2amp rectifiers doing nothing, AC side it can supply 5amps at 13v (AC) to 19v when rectified..
    Can i just parallel them? Otherwise i'll dump these and use 4 regular 1 amp diodes..
  2. (*steve*)
    25,501
    2,841
    In general it's a bad idea to parallel semiconductors in this manner.
    However if you connect three of these 2A rectifiers in parallel and place a 0.1 ohm resistor in series with each AC input they will share current reasonably well.
    1A diodes are not a better solution :)
  3. (*steve*)
    25,501
    2,841
    Oh, I'm assuming the 2A rectifiers are bridge rectifiers. Is that correct?
  4. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    Yup i got 4 unused (2amp / 240vac) but i got a feeling i might need to use like a 0.1ohm out on each to load balance?
  5. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    4 diodes (each carry 1amp max)
    In a bridge rectifier combo, what is wrong with doing that? (They won't be in parallel)
  6. davenn
    davenn Moderator
    13,947
    1,988
    what is wrong is that you haven't specifically told us what current you are likely to be drawing from the PSU ??
    or what the current rating of the original diodes was ?
  7. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    I did... (5amp/13v multiply it for VA) but that's not the point
    The point is, i can't use them in parallel without balance loading, so i'll use 4 diodes as i normally do without using these all in 1 bridge rectifiers ...
    But Steve, in every bridge rectifier circuit i've ever built, i always used 4 diodes, that's how it's done, did you think i refered to parallel loading of the diodes? (In which case no)
  8. (*steve*)
    25,501
    2,841
    OK, let's go back to basics.
    What is the load current?
    If it's up to 1A you can use either the 2A bridge or 4 x 1A diodes.
    If it's up to 2A you can use the 2A bridge
    If it's above 2A you can use a pair of 2A bridge rectifiers, each with a pair of 0.1 ohm resistors on each of either the AC inputs or the DC outputs (that's 4 resistors for 2 bridge rectifiers).
    4 x 1A diodes will make a single 1A bridge rectifier.
    OK I read (now I'm awake) what I missed before that the transformer is rated at 5A AC. That's only 3.5A DC, so a pair of 2A bridge rectifiers will be fine.
    Likewise 4 regular 4A diodes would be fine (actually, probably better).
  9. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    Alrighty then, 4 x 2 amp .6v diodes it is!
    Shame, i wanted to use these useless 2 amp rectifiers, all sorted, cheers
  10. (*steve*)
    25,501
    2,841
    4 x 2A diodes is *exactly* the same as your 2A bridge.
    Did you mean 4 x 4A diodes?
    davenn likes this.
  11. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    Alright, ok i'm with it now and why i got confused...
    All sorted, 4* 4amp diodes on the way :)
    Thanks!
    (*steve*) likes this.
