R
[email protected]
Here's my story...
I took apart my lcd panel to make one of those DIY front projectors.
Got almost everything going except this...
There are two PCBs that connect to two sides of the TFT panel (one for
vertical and one for horizontal). They are connected by a 3/8" wide
~19 connector paper-thin plastic connector/cable. In order for the
PCBs to sit correctly for the projector, I need an "extension cable"
for this. The cable goes into a plastic snap-in mechanism on the other
PCB.
Look at these pics for info:
http://mywebpages.comcast.net/rajraj/lcdpanel.html
The extension I need is for the smaller end.
ANY INFO is appreciated on the topic of connecting the two PCB any
which way.
I can also send very high res versions of the above pics if it would
help.
Thank you,
Rajan
PCB.
which way.
help.
Thank you,
Rajan
