Panasonic TX-32DS503E blinking red light.
Discussion in 'Troubleshooting and Repair' started by AlenZGB, Mar 11, 2019.
  1. AlenZGB
    AlenZGB
    174
    5
    Feb 19, 2014
    Hello.
    i have Panasonic TX-32DS503E, when i start it, it turn on after startup green light it turns to red
    and start blinking at the same speed. I read somewhere that its problem with some led strips on LCD but im not sure.
    Any help is wellcomed, trying to fix it for my daughter.
    Dont mine the background :rolleyes:
    Video is below.
  2. Bluejets
    Bluejets
    3,991
    824
    Oct 5, 2014
    No video below.
    Description sounds like a power supply problem.
  3. AlenZGB
    AlenZGB
    174
    5
    Feb 19, 2014
  4. 73's de Edd
    73's de Edd
    2,842
    1,208
    Aug 21, 2015
    Sir AlenZGB . . . . .
    I don't give much hope on it, but is this being the PS board that is within your set ? . . . . being of a # TNPA-3487 series.
    They sure don't care for technical support . . . . . it's about as difficult as finding any info on a frammywhackus for a '72 Yugo !
    HOT LINK . . . . .
    https://i.ibb.co/1YcQjQx/TNPA-3487aa-top-Power-Supply.jpg
    ( Clickee-clickee mousie . . . . makee pickie mo' biggee ! )
    73's d3e Edd
    If at first you don't succeed . . . . . skydiving is not for you !
  5. Tha fios agaibh
    Tha fios agaibh
    2,088
    699
    Aug 11, 2014
    You don't say how many blinks you get but I counted 4 and then video ended.
  6. AlenZGB
    AlenZGB
    174
    5
    Feb 19, 2014
    i didnt say, thats correct,but as i can see it blinks the sam half an hour, my guss is that is 1 blink code. blink pause blink pause and so on.
    today, after my daughter go to sleep ill dissasemble the tv and take pictures.
  7. Tha fios agaibh
    Tha fios agaibh
    2,088
    699
    Aug 11, 2014
    I blinks continuously? I thought it would turn on green and you start counting the red blinks. It should blink up to 10 times and then likely shut off to protect itself.
    Try unplugging boards one at a time and see if the led light goes back to solid green.
  8. AlenZGB
    AlenZGB
    174
    5
    Feb 19, 2014
    Its positive, LED stip is faulty. on 2 of 3 LED strip has one faulty single LED.
    Ill maybe replace the LEDs then try to fix anything else if its bad and wont start the TV.
    Video below, sorry for dark video but if i turn the lights on there wont be difference between good and bad LEDs.
