Panasonic TV Shutdown
Discussion in 'Electronic Repair' started by Guest, Nov 30, 2003.
  1. Guest
    Guest Guest
    I have a 7yr old (Mfd: 8/96) Panasonic TV model CT-27G11U that seems to
    sporadically shut down. There is no popping noise or video changes prior to
    shutdown. After shutdown it will not power on again for several seconds.
    Some days it will shut down several times after varying delay times (some
    quite short), other days - not at all. Any help would be appreciated.
    Thank you.
  2. Dry joint?
    __ __ __ __ __
    Regards, Chris
    [spamblock used]
  3. Do you mean a cold solder joint and if so, where do I look for it?
  4. David
    David Guest
    Probably means a cracked solder connection. Look for it in the tv set.
    Your description of the problem is way to vague to be any more specific.
    Anything from the system control, jungle ic, sweep, power supplies, can
    cause an intermittent shutdown.
    David
