Sir C.J. . . . . .
Well . . . . . in making these initial observations . . . . . the back cover on one of those units lists up to max potential 270 watts of max power consumption for on one of those units.
Plus the list price seems to be up un the 500 hunna dollar category, so this unt would be more than a glorified shoulder toted "Boom Box".
So it looks like your woofers amp can handle it, but the other set of R and L amps and power audio drive to their speakers is failing.
Initially, if only affecting ONE channel, one would possibly want to expect a speaker voice coil problem BUT this would NOT be the case with BOTH speakers cutting out.
(Do check the interconnecting wiring integrity to those speakers. )
So one major point of further interest in trouble analysis would be if the unit was initially started stone cold and the volume upped, does that cut out occur ?
AND if that situation is being true, is it true on ALL all of your audio input mode sources ? ? ?
The other possibility is that this situation is only occurring AFTER the unit has initially played for awhile, and its power amp components have then started thermally warming up.
Then, that is when the unit would fail, AFTER the volume was then advanced up.
Can you tell us if that is being true ?
If the latter is the case come back for feed back on further analysis , if the first situation consult a Swami.
PLUS . . . . . additionally to Sir Martaines query, above . . . . . Are any other R and L supplemental speakers
being " haywired " into the system?
73's de Edd
