Panasonic PV-8661 won't accept tape
Discussion in 'Electronic Repair' started by L Mehl, Dec 21, 2003.
  1. L Mehl
    L Mehl Guest
    Hello --
    Is it worth it to fix this problem?
    The metal-bottomed cassette carrier no longer positions itself just behind
    and at the bottom of the opening in which a tape is inserted. Instead, it
    remains elevated above and at a distance from the opening.
    Thanks for any suggestions of the parts and cost involved, and/or whether or
    not to discard it.
    L Mehl
  2. Sounds like it's not opening the cassette lid as the tape moves in.
    Mark Z.
  3. L Mehl
    L Mehl Guest
    The lid is stuck in the "up" position.
    L Mehl
  4. Sofie
    Sofie Guest
    L Mehl:
    Most likely a mechanism timing problem..... fairly inexpensive to have a
    shop re-time, clean or replace mode select switch, and maybe a gear??
    At the very least you should TAKE it to a repair shop to obtain a repair
    cost estimate so you can make an intelligent repair decision with facts.
    A tech really needs to see it first hand otherwise it is all guesses.
  5. L Mehl
    L Mehl Guest
    Thanks Daniel
    Larry
  6. Nick Charles
    Nick Charles Guest
    For an older unit, it might be worth the aggravation of some shop time
    if you think it will yield a few more years service, otherwise this
    would be a smart time to consider a new one, while VHS decks are still
    somewhat worth their junk-store prices.
    These things are made to fail, and when they start screwing up in
    weird ways, you don't pay a tech $80 to (maybe) fix it, you do
    yourself a favor and TOSS it.
    I mean, I'm like most people ... I'm not wasteful, I care about my
    equipment, I treat it respectfully and I'll attempt to repair anything
    myself first, but I don't reason with consumer trash from asia. I
    usually curse the reason we no longer have a choice in this fucking
    country, and go buy another one.
  7. L Mehl
    L Mehl Guest
    Nick --
    Thanks. Good advice.
    Larry
